shallow sub
shallow sub
While browsing the net for subs and such, I came across this: http://www.thetwistergroup.com/store...1661&source=fr
with that small of enclosure needed, 2 should fit real easy in the floor.
Think there is enough room in the stock space for that?
I went with a JBL 8" in the stock location for times when I need the storage place, and I have a 12" in a box when storage is not an issue. The 12" plugs into a 1/4" jack mounted in the back. When plugged in, only the 12" is powered, unplugged and the 8" is powered. I was very pleased with the low end response and output from the little 8. No it is not as loud as the 12", but the bass is tighter and more linear than the 12".
