Sirius Connect compatibility w/factory radio
Old 01-13-2010 | 09:22 PM
gwizz's Avatar
I just purchased a 2009 HHR fleet vehicle which didn’t come with the XM package. When I search on GM factory radios I cannot seem to find any for the HHR, but I do find a picture of what exactly resembles the face of my radio and fairly sure the factory radio is a CD MP3 Delco XM radio 25974801. I want to install the GM Sirius Connect Satellite Radio Kit: SIRGM1 SIR-GM1 and us my factory Head Unit, but none of them have any information on HHR’s. Any help shedding some light on my dilemma would be appreciated.
Old 01-13-2010 | 10:47 PM
IgottaWoody's Avatar
Just go aftermarket and plug into the aux......easier and cheaper...
Old 01-14-2010 | 07:12 AM
gwizz's Avatar
Thanks for your recommendations but I’m not sure what you mean by aftermarket, is that using my old Sirius radio setup I had in my last vehicle. If so that’s what I’m trying to avoid I’m going for a clean look. I would like to use Sirius Connect through my current head unit and cost isn’t that much of an issue. Is it possible to use Sirius Connect? I can’t find any info supporting info stating it will work with the factory system.
Old 01-14-2010 | 07:33 AM
NxlKing2304's Avatar
I think it will only work if your radio has or had the XM function on it!! If it doesn't, Then i believe the answer is NO.
Old 01-14-2010 | 02:45 PM
gwizz's Avatar
When I push the Data button I get a message XM feature.
Old 01-14-2010 | 03:35 PM
oneton's Avatar
qwizz: see if this what your looking for. This is for a 09 HHR with the upgrade system. Just Looked at the other for no upgrade and it is the same one;
http://www.crutchfield.com/p_607SCC1...&tp=6953&avf=N
Old 01-14-2010 | 09:00 PM
gwizz's Avatar
Thanks Oneton, I kinda thought thats what I was looking for, but couldn't find any spicific documentation.
Old 01-17-2010 | 01:50 PM
bowtie3's Avatar
Have you installed this yet? I am curious to what else you need?
Old 01-17-2010 | 02:07 PM
gwizz's Avatar
No I haven't bought the Sirius Connect yet I'm still a little fuzzy on which adapter I need to get. The radio in my ride is Delphi Delco system and I cannot find an adapter for that system.
But once I am certin on the adapter I'm going to buy and install...I miss my Sirius. The Job should be a snap I had the dash apart eariler to get the modle and part # of the radio took about 15 minuites to take apart and re-assemble.
Old 01-17-2010 | 03:01 PM
oneton's Avatar
This should help with which adapter you need.
Call 1-888-955-6000 or get live online chat, 8 AM to midnight, Eastern Time. E-mail us at solutions@crutchfield.com.
