Sirius Ragio for HHR
I'm trying to hook up my Sirius radio to my HHR and I want to use the FM Direct Adapter so I can use the car antenna. The problem is that it won't plug into it. I went to the store and bought what I was told the correct adapter to make this work but they don't fit. Can anyone help me or give me direction? I would really like to use the car antenna instead of mounting a satellite antenna to the car. Any help would be appreciated, thanks.
If you need to find the right adapter or anything for sirius I would try www.tss-radio.com. I have the Sportster replay with the magnetic antenna coming right out the rear hatch. Looks sharp and no problem running the wire.
To pick up signal, you still will need a satellite antenna. Some of the antennas are only around 1" square by 1/4" high. I put one of those small ones on top of the dash of my Nissan Quest with some double sided tape and it picks up just fine there through the windshield and it's hardly noticeable.
If what you are refering to as the FM direct adapter is the small inline antenna wire that couples between your stock radio antenna and your headunit FM antenna input this only helps with cars that have bad FM modulation. http://www.crutchfield.com/S-S0T77lQ...px?I=607FMDA25 This dosn't eliminate the need for an actual satelite antenna it just helps your satelite reciever transmit the fm signal that it uses to transmit sirius signals to your head unit rather than through the air. (make any sense) I had to use this on a 96 Nissan maxima with my Sportster for what evere reason because with out the fm direct adaptor I had alot of engine noise. Hope this helps.
