Sound Deadening
In a roundabout way it could be in general the same. Sound deadening is an asphalt based product with the adhesive on one side. So generally yes same thing. The Raamat bein a thinner product is more pliable and easier to mold without a heat gun to conform to panels.
Dynamat is very expensive and not even the best out there.
asphalt based deadeners are good but still not the best.
Raamat is good stuff, I have used it in the past.
But the best by far I have ever used is Second Skin,
The damplifier Pro is a foil backed butyl based mat. it has score lines so that when you adhere it down and smotth it, air can escape from underneat. This allows for a perfectly bonded surface/
Butyl is not effected by heat. asphalt based deadeners can melt and become soft.
Second skin also makes a liquid that can be painted or sprayed on. Its good for tough areas to stick you arm into.
www.secondskinaudio.com
I used secondskin also, works great!
