Stereo hardwire questions!!!!
Old 12-26-2007 | 08:03 PM
1SICHHR's Avatar
Unhappy Stereo hardwire questions!!!!
Hey everyone, I am looking for an easy to read wiring diagram for hard wiring an aftermarket radio into my HHR. I have seen some on here but the ones I saw on here are very difficult to read. I saw in one post that SOCal HHR'S said they have an easy to read diagram. Does anyone have that for me?
I was also wondering if this will in any way effect my factory remote start? I know you lose your chimes but I can't have it effect my remote start.
Thanks in advance for any help you may provide.
Old 12-26-2007 | 10:10 PM
1SICHHR's Avatar
Anyone? I talked to Sindydix tonight and she was on vacation but she said some of you should have this or know where I can get it.
PLEASE, I'm beggin!!!
Old 12-26-2007 | 10:27 PM
stick's Avatar
I'm sorry to say that I can't point out a good diagram for you, but there is a good how to on the site. It tells you what wire colors control what part of the stereo. I used it to splice into the factory harness for my amps. I tells what color wire is for power, ground, and all the speakers, as well as all the other junk. Just make sure you have the one for the head unit and not the amp in the back if you have the premier unit. Good luck.
Old 12-26-2007 | 10:42 PM
1SICHHR's Avatar
Thank you, After hours of looking I finally have a list of wire colors and connectors that I think will work.
Is there anything else that can get screwed up by this though? I know I will lose chimes and the click click of the turn signals but I really don't want to screw anything else up.
Old 12-27-2007 | 09:51 PM
SIRESMERPH's Avatar
this is what i used for wiring https://www.chevyhhr.net/forums/audio-video-17/audio-wiring-9439/
hard wired it in
Old 12-27-2007 | 09:52 PM
stick's Avatar
Depends on what you are wiring. Are you changing the whole head unit or adding a amp? I kept the stock head unit but added a pair of amps, speakers, and subs. I was able to keep all the function, chimes, ticker, and steering controls by only cutting the wires I had to. If you are changing the head unit I would suggest going with the wire harness route and spend the money. I know that they may seem expensive, but better that then ruin something! Thanks for finding the wire colors SIRESMERPH, that is what I used.
Old 12-27-2007 | 11:18 PM
1SICHHR's Avatar
I am changing the headunit. Have you heard of other issues? I have searched and searched but I have not heard of any other issues. I am ok with losing the chimes and turn signal click but I don't want anything else screwed up.
Anyone out there that has done this and had issues? I am specifically worried about my remote start.
Any more input would be greatly appreciated.
this is what i used for wiring https://www.chevyhhr.net/forums/showthread.php?t=9439
hard wired it in
Thank you for this info!!! It took alot of searching for me to find that info. That is perfect.
Old 12-30-2007 | 12:20 AM
SIRESMERPH's Avatar
Thank you for this info!!! It took alot of searching for me to find that info. That is perfect.[/QUOTE]
no prob!
Ghost09
03-22-2013 11:54 PM
ecl
03-20-2010 03:31 PM
ColeTrickle
06-26-2008 11:40 PM
outlandishhhr
03-12-2008 02:13 PM
courthousedeb
05-14-2006 06:40 PM
