Stereo Install
Well if you don't have the pioneer system then I would suggest the Metra XSVI-2104 harnes. This retains the RAP feature but does not keep the chimes. For a din and a half go for the 99-3302, for a double din the 95-3302. Antenna adapter is the 4-cr10. ( all metra part numbers)
Oh yeah! I forgot to mention the 70-2104. With this harness you will need to run your own accessory wire to the fuse box. I would sugest going with XSVI-2104. They range around the $50 or so price point.
The dash kit fit pretty good. I had to go with the LAN-04 harness due to the pioneer system. Good luck with the install!
Well what if you sell the car? Or ever wanna go back to the stock radio for whatever reason? Not so much funk it up, its just a pain in the ass. If for some reason you did mess up, I dont wanna know what it would cost to have a new harness put in, if it needed it.
ok I think this is everything I will need right?
http://cgi.ebay.com/Chevy-2006-Hhr-R...QQcmdZViewItem
