Stereo Install
You will need:
Mounting Bracket
Wiring Harness
Antenna Adapter
WireTap for the fuse box from your 12v source
The stock wiring harness doesnt have one so youll wire it into the harness then tap into a fuse somewhere into the fuse panel.
I had to do that on my brothers 07 silverado and my 06 cobalt ss/sc.
Mounting Bracket
Wiring Harness
Antenna Adapter
Newbie Audio Installation
Well if you don't have the pioneer system then I would suggest the Metra XSVI-2104 harnes. This retains the RAP feature but does not keep the chimes. For a din and a half go for the 99-3302, for a double din the 95-3302. Antenna adapter is the 4-cr10. ( all metra part numbers)
what features would be lost between the GMOS lan03 and xsvi-2104? i don't have pioneer nor have onstar on my orange HHR 06 LS.
Definately, if you are going to replace the stock head unit, get a harness. How much did you spend on the LCD video unit? Why drop big money on the head unit, then skimp out on the wiring? Remember, your sound will only be as good as your wiring. If you aren't good at spliceing and soldering, then just buy the harness. Oh, and show pics when done.
GMOS lan3 versus xsvi-2104 harness, pro's and con's?
Sorry, but I cannot answer that. I stayed with the stock headunit and changed everything from there on out. All new speakers, two amps, and three subs in the rear. I spliced my wires. I don't have the onstar, but I do/did have the pioneer system. Some say you lose, others say you don't. Just depends on what harness you get. I did however keep all my chimes/buzzers and whatnot.
