Stereo questions...
Stereo questions...
Hey guys, I know this has probably been asked a lot, but my search only turned up vague info and a dead how-to link. I was wondering what the best way to pull the waterfall off is? I've read that i just need to pull the top or from the vents but i'm pulling so hard i'm afraid i will break the vents! Also what exactly do i need for an aftermarket double din deck? I have a 09' LS with the 6 speaker stereo.
I believe i need the GMOS-LAN 03 wiring harness ( Axxess GMOS-LAN-03) ,an antenna adapter (Metra Electronics 40-CR10) and a installation kit (Metra Electronics 95-3302). Does this sound right? Its mostly the wiring harness i'm having the hardest time with...
Thanks guys!
Thanks guys!
I'm not an expert but my 09 needed the 04, think the difference is Onstar. The stereo shop install 2 of them that I have and they only worked a few minutes, they are both out on the shelf. They used a Pac11 adapter and I havent had any problem for 2 years.
