Stock amplifier Wiring
Can someone please repost the stock amplifier wiring for the pioneer system. All of the old links and pdf's are broken. I am trying to run a mono amp through a line level converter, so do I only need one side of the wires? Maybe someone has a better way of doing this. Thanks
Audio Amplifier X1 (UQ3)
Pin Wire Circuit Function
1 0.5 D-BU/WH 346 Rear Subwoofer Speaker Output (+)
2 0.5 L-GN/BK 1794 Rear Subwoofer Speaker Output (-)
3 0.5 D-GN 1795 Rear Subwoofer Speaker Output (+)
4 0.5 L-BU/BK 315 Rear Subwoofer Speaker Output (-)
5 2 BK/WH 751 Ground
6-7 -- -- Not Used
8 2 RD/WH 640 Battery Positive Voltage
Audio Amplifier X2 (UQ3)
1 0.8 YE 116 Left Rear Speaker Output (-)
2 0.5 BN 199 Left Rear Speaker Output (+)
3 1 D-BU 46 Right Rear Speaker Output (+)
4 1 L-BU 115 Right Rear Speaker Output (-)
5-8 -- -- Not Used
9 2 D-GN 117 Right Front Speaker Output (-)
10 2 L-GN 200 Right Front Speaker Output (+)
11 1 TN 201 Left Front Speaker Output (+)
12 1 GY 118 Left Front Speaker Output (-)
13-16 -- -- Not Used
Audio Amplifier X3 (UQ3)
1 0.35 BN 1999 Left Rear Low Level Audio Signal (-)
2 0.35 TN 1946 Right Rear Low Level Audio Signal (-)
3 0.35 BN/WH 599 Left Rear Low Level Audio Signal (+)
4 0.35 D-BU 546 Right Rear Low Level Audio Signal (+)
5-7 -- -- Not Used
8 0.35 PK 314 Radio On Signal
9 0.35 L-GN/WH 512 Right Front Low Level Audio Signal (+)
10 0.35 D-GN 1947 Left Front Low Level Audio Signal (-)
11 0.35 L-GN 1948 Right Front Low Level Audio Signal (-)
12 0.35 TN 511 Left Front Low Level Audio Signal (+)
13-15 -- -- Not Used
16 0.35 L-GN 1011 Remote Radio Control Signal
6-7 -- -- Not Used
5-8 -- -- Not Used
5-7 -- -- Not Used
also you can use the PAC OEM-GM1416A-- this is an interface box that plugs in behind the radio and provides 2 sets of RCA's out for adding amplifier and also the remote trigger wire... just be careful of the cheaper line converters out there-- they dont have the impedance protection (matching) and can result in a burned out channel on the amplifier. just my
There is also a thread on here about using the factory wiring instead of a line converter. Apparently, if you have the 7 speaker system, there are already line level wires, you just need to solder on some RCA plugs.
HPVOHHR
02-17-2010 08:32 PM
