stock radio without xm
From the pics of your car, you don't have the xm antenna, so I think you may have the base unit which means no xm.
im sure if you have the premium system in a lt hhr with a sub speaker you already have xm just activate it by calling or going online to xm. hit your band button on your radio if you have fm1,fm2,am and xm. then if you have xm i think its station 1 on the xm band is your radio id number you will need this number to activate xm. if you dont have any of this order a premium xm radio and antenna from gm then everything will look factory
Apologies for grammar typos..I'm typing this at work
I have no antenna in the back but my premium system indicates it's XM ready " cat button"
i have the same radio - I hit CAT and Xm appears and then disappears . Would that mean I need a satellite antenna and the Xm tuner to use the built in Chevy system . Aybody buy the tuner form Chevy . Must be pricey .
JW
JW
