Sub questions.
Sub questions.
I have a 2007 hhr and it has the factory sub in it. Have several questions.
If I put a stronger amp on factory sub will it hit harder. Or would it be best just to replace sub and amp to get harder hitting base. I am interested in fosgate sub, anyone put one in their hhr. If so what model. Anyone know how mush air space is in factory box?
The most bang for your buck is to add an amp and large box in the cargo area, but then you might need to remove it to carry cargo. Id go for dual 12"
The factory sub wont handle any more power than the factory amp. Also the factory sub is meant to work in the factory enclosure and most aftermarket subs wont work as well in the factory enclosure. So the best way to upgrade is to add a new amp, new box, new sub.
