Subwoofer Volume Control Install
I installed this because I was concerned about the different levels of bass that change from song to song. I used a Peripheral PRC1 line level controller. They are $15 on ebay. All I did was remove the volume pod from the mounting box it comes in. Then I removed the center dash by by grabbing between the inside of the 2 air vents pulling up and back. I found center and drilled 1/4" hole and mounted the volume knob.
alexrckid
11
02-26-2012 07:46 PM
