is there a remote wire?
Old 11-16-2009 | 05:32 PM
lefthandedrighty's Avatar
Question is there a remote wire?
hello fellow HHR owners
had my HHR for about 6 months, and i love it
i have the non premium, 7 speaker radio system
i like the radio, like the aux in and the MP3 cd capabilities
i just want more bass, and i want to add a sub
ive had aftermarket systems in all my cars, even had a radio or 2 stolen, which is a terrible feeling
i want to keep the stock head unit, but add my amp and sub
i have an MTX crossover, which can convert the signal from the speaker wires, to an RCA output for the amp so im covered there
but, i really dont want to have to run my own remote wire to a toggle switch somewhere
do these radios have any sort of a remote wire?
it seems like the premier system with the stock sub has one for the stock amp, but, unfortunately, i dont have that
having a toggle switch can be ok, and im not against that completely, but i just want to avoid having to run a ton of wires back and forth
if i did have to run my own remote, could i come from the fuse box so i dont accidentally leave it on?
thanks in advance
Old 11-16-2009 | 09:49 PM
Daddy4life85's Avatar
Just tap off the stereo key turn on wire or something. Use a volt meter or test light to find one that works only when the key is on. Although I think there may be a wire dedicated to remote wire because there is an optional sub in the HHR.
Old 11-17-2009 | 10:51 PM
well, i dont have the premiere stereo, therefore, i dont have the amp or sub
i doubt i have the wiring
and, i think you might be talking about tapping into the 'yellow' ignition power of the radio
i guess thats an option, but id rather run it from the fuse panel
i didnt want to have to go this route
maybe ill just eliminate all this, get an aftermarket head unit and be done with it
probably get a higher quality sound anyway
Old 11-18-2009 | 12:28 AM
unique_w's Avatar
After Market Audio Ampifier
The radio ON signal comes from pin 3 on connector C2 of the radio.
The power to the OEM amp comes from a 20 amp fuse (fuse panel right side of console) fuse #6.
Feed from the radio connector C2 pin 3 to an after market amp that accepts a power on signal.
20 amp power for an after market amplifier can come from the 20 amp fuse #6 right side of console, (assuming the amplifier does not need higher current requirements than 20 amps.)
Or -
If no after market amp signal is available at the after market amp -
Use a 20 amp (load current contacts) 12 volt relay (assuming you are not using an amplifier of higher current requirements) power the relay from C2 pin 3 on the radio. Power one load contact on the relay from Fuse #6 at the fuse panel right side of console. Power the amp from the other load contact of the 12 volt relay. The relay can me mounted near the fuse panel.
If you need a drawing advise ?
Do you have the OEM radio wiring schematic ?
Old 11-18-2009 | 10:54 AM
no, i dont currently have the OEM wiring, but im sure i could find that on here with a search
thanks for the info though, thats pretty much what i was looking for
im looking forward to not having to run a power wire all the way from the front of the car to the back for an amp
the battery is right there, which is nice
Old 11-18-2009 | 01:09 PM
prod's Avatar
I used an add-a-fuse from the sunroof fuse in the fusebox. This keeps the retained power function and will keep the radio on for a while after the key is removed, however it does not allow for chimes when the door is opened and the ignition is off.
Old 11-24-2009 | 01:13 PM
Sno White's Avatar
Just to be sure this is not misunderstood. My understanding is that this wire feeds the stock Amplified Antenna and is not what turns on the radio. It is an output from the radio to the antenna to save power when the radio is not in use. Is this correct?
The signal that turns off the radio through RAP is through the Low Speed GM LAN or CAN.
tahenke
08-26-2018 04:14 PM
sttcharl
11-21-2010 05:07 PM
prod
12-10-2008 10:32 PM
BlackHHR06
09-07-2007 09:17 PM
keverz146
03-12-2007 11:56 PM
