Is this true?
Is this true?
I made an appointment to have my stock speakers replaced with some Alpines. After I got there, the salesman recommended an amp. Then he told me the whole car would have to be rewired. I said forget the amp just replace the speakers and use dynamat. He told me the Alpines would not work with my premuim system. I don't have the sub. Just the stock deck with the 4 speakers and tweets, single cd with a PAL installed.
I wanted the Alpine SPR 17C and 17S. So was the gentleman correct or just looking to jack up the install price?
Parts needed are as follows....An amp(duh ), amp power wire kit of appropriate gauge to the cuurent demands of the amp(10,8,4ga...etc), two line convertors for the factory radio to RCA adaptation to retain front/rear fader control, two appropriate length RCA connectors and a "9-wire" to run from the amp back to the radio to catch all the speakers factory wires behind the radio.
Or you could just get an amp with high volt imputs. Some amps out there have speaker ins as well as outs. As far as speaker off the fac deck. You would do well with ones that are high on the sensitivity side. Like the Infinity Kappa's and Referance lines they have a 93 dbl sensitivity rating. I think the Alpines are in the low 80's.
