Tweeter thread.
Tweeter thread.
I want to put tweeters in the middle storage area.
The vifa's on ebay are all about 2-3" wide for the bracket so they won't really fit in the stock tweeter location and I wanted to make a left and right channel for both passenger and driver (keeping the stock tweeters for fun and because almost no decent tweeters will fit without cutting)
I was also thinking about having 4 tweeters in the center storage area. 2 pointing forward and 2 pointing outside the front windows.
since I would be building a small box for them, I could just take the box out when needed and it wouldn't require cutting or hurting the interior in anyway.
my other idea would be to make a pod for the windshield to dash and a-pilar corners so that you could fit a larger diameter mounted tweeter without cutting anything.
any input appreciated.
BTW most car audio tweeters are garbage as far as im concerned.
get some vifa's and you'll understand why
I have some vifa's right now and they have no hisssssssss because they are quality tweeters. $15 each shipped from ebay and they blow the doors off of the $60 pairs of tweeters at local car audio shops.
I know "$60 for tweeters, what did you expect" but seeing as how you can get way better for less, used, there is no point in going to best buy and spending $100+ on tweeters.
tweeters in the middle cubby would give the passenger and driver their own left and right channels, as apposed to having the left/right all the way on the other side of the car, out of balance.
How would you compensate for time correction with that many channels? you would never get a proper sound stage? Also, you would have way to much of the higher frequenies, you would need to compensate for your mid bass.... I agree with EricB that a full range sopeaker would sound way better, trying to put more bass in the front. Maybe I'm worng, but to each his own.
that tisssss only happens with cheap tweeters.
I know Vifa tweeters are descent, I'm not a total dumbass.. But there is a point where you have too much tweeter. But as far as tweeters in the cubby.. nooooo.. a full range will work much better, but make sure you cross it over at 10k. The reason I say to cross it over at that is because that's where the human ear can start to 'localize' where its coming from which would defeat the purpose of a center channel, which is why your theory will not work. Left is left, and right is right, center is center. Just run a center channel full range driver and cross it over at 10k. And while your at it, grab yourself a nice sound processor that can process a center channel.
