Upgrade the bass
You can get creative and wire an Audio Control Epicenter inline from the HU to the subwoofer amp. It will recreate the lowbass that GM has filtered from the HU with non-defeatable EQ. Just be careful, the stock amp is weak and the stock woofer is designed to be weak right along with it. Bass below about 50hz might be too much for the flimsy woofer and plastic enclosure.
does anyone know if the tweeters are in the same channel as the door speakers, or are they assigned seperately? I dont want to have to splice or lose any of the stock speakers (except the stock sub).
What wires going to the amp are the RCA's ill need for the new amp?
Thanks
Subnbound
The Epicenter and an EQ are great ideas! Wish I would have thought of that before I redid my system. I have no issues getting low bass from my stock stereo. Plus the Audio Control products (at least the EQ's) are equiped with line level adjustments so you can boost your signal going to your factory amp.
Shallow 8" Sub
Would putting in a shallow sub like a Kicker 08CVT84 and running it from an aftermarket amp make a difference?
http://www.onlinecarstereo.com/CarAu...roductID=19321
