USB Radio
Old 03-15-2012, 07:46 PM
axxsys's Avatar
Originally Posted by Pretzel
Deke40,
Ive only had one act up for a day then it started working again.
I use only the 16gb Pico mini (thumb drives) in mine. I leave them in. They work flawlessly and hold a boat load of music :) I also grind off the landyard ring for a lower profile.
thanks for USB info. much stealthier.
axxsys is offline
Old 03-15-2012, 07:56 PM
axxsys's Avatar
Originally Posted by kreesto
Thanks Deke40. I have an iPod so that's what I plan to use. Do you have any experience using an iPod with the GM USB radio?
I have the Ipod through the aux jack and the flash drive in the USB port and alternate between the two.
axxsys is offline
Old 03-15-2012, 09:35 PM
Deke40's Avatar
I can play my P2 through the RCA jack and set it to the "Songs" selection and it will play the songs alphabetically through the entire 2100.
The OEM radio sucks on it's shuffle as it has to many repeats. I finally found out if I grab the songs from a cd and drop them in a folder on my pc then grab all of them to one of my USB drives they will play straight through on the "no shuffle" setting with no repeats.
I will never buy another car unless it has a USB port and hopefully a minimum 20GB harddrive. We do get spoiled with our toys.
Deke40 is offline
Krusty
06-09-2012 02:45 PM
capp002
10-18-2011 02:24 PM
SargeRN
10-05-2011 08:21 AM
Sno White
"How To" Tutorial Library
11
08-26-2009 05:48 PM
KY Dave
07-26-2006 04:27 PM
Quick Reply: USB Radio
