where to put Switches?
I am considering some mods, and one of them is adding an aoogah horn. I want to leave the original horn in place for the time being.
I have a couple of other ideas for things to wire up, but I am wondering where to put the switches? I want it to look good.
I am tempted to put them in the upper glovebox, since that way they are hidden.
Any other ideas or how did you do it?
Thanks,
Matt
Thanks,
Matt
I was looking down there.
The only reason why I have not planed for there, is during an accident(heaven forbid), you can get impaled on things down there. I keep leaning toward inside the upper glove box. Or maybe building a flat panel that sits in the change tray...
here is one way to do it if you dont wont a switch showing... its pretty neat little trick... I use this for turning on/off some cold cathodes and led lighting in my interior.. works very nicely and is hidden from view... its a basic single channel remote relay for up to 15amps 12vdc...
http://store.pcwebshopper.com/lorm12v15are.html
