Will PAC AOEM-GM1416a work on 2009?
Their site lists 2006-2008 HHR
http://www.autosoundcentral.com/PAC_...oemgm1416a.htm
Anyone use this on a 2009? I'm doubting much changed from 08 to 09 but you never know.
The reply from AutoSound is a little limp
From: AutoSound Central [mailto:autosoundcentral@sbcglobal.net]
Sent: Thursday, February 04, 2010 11:06 AM
Subject: Re: PAC AOEM-GM1416a GM Add an Amplifier Adapter
Hello,
The connectors are the same so it should work. Thanks Steve
Hello,
According to this site it will work if you have standard 11 bit Radio with 14 or 16 pins.
http://replacementradios.com/product...oducts_id=1505
I just purchase one for my 2010 HHR LT with radio 1 step down from premium no factory sub, XM disabled.
Also purchased JL2 500.1 mono block amp and 2 JL 10WX 10" 4ohm subs in sealed boxes.
I'm going to install the amp in the spot where the stock sub would be and put a connector plate in the side molding Speakon connectors, so if i want to remove the subs its simply unplug the boxes.
