Will these LCD Headrests Fit?
Old 11-20-2007, 05:31 AM
groovielou's Avatar
Specs:
General Features:
Black artificial leather headrests with black LCD frame
7-inch TFT LCD screens
163 x 123 mm (W x H) active area
High Resolution Panel : 1440 x 234 pixels (W x H)
4:3 (standard) or 16:9 (widescreen) aspect ratios
Brightness: 300 cd/m²
Contrast ratio: 350:1
Automatic switching between PAL/NTSC
Viewing angle: 120° horizontally, 100° vertically
Input terminal: AV (composite)
Control mode: manual or remote control
Response time: 10 ms
Adjustable headrest: forward and backward adjustment 35°
Adjustable tube diameter of headrest: 10, 12, 14 mm
Adjustable tube distance of headrest: stepless adjustment within 135 - 185 mm
Applicable to all car seats with headrest tube diameters of 10, 12, 14 mm and tube distance within 130 - 190 mm
Thanks,
Groovielou
groovielou is offline
Old 11-20-2007, 01:02 PM
laborkei's Avatar
Hello Lou !
I am watching your post with great interest.
For some time I have been wanting to install the DVD Player Headrests, but have not found a good source for them at a resonable price.
I was at BestBuys the other day, and they had a set made by Jenson on display. I borrowed one, and it fit perfect. But, they wanted $2K for the pair, and they wanted to install them.
I can't answer your question to your post, but I would think the manufacture would tell you what vehicles they would fit.
If anyone knows were I can find some at a resonable price for a 07 HHR Ebony Cloth, please send me a email. The ability to send wireless audio to the stock radio would be a plus...
Thanks,
Keith
laborkei is offline
Old 11-20-2007, 01:14 PM
R CA HHR's Avatar
These are the ones I purchased about a year ago and so far no issues other thean the light grey color they show is actually alot darker grey but they gave me a 40.00 refund and I think I like the contrast anyway.
If they have the adjustable rods then there hould not be any problems with the fitting, mine were ant they went in very easy.
Hope this helps, you can always measure the distance between your rods and double check!
http://cgi.ebay.com/2-x-7-LCD-HEADRE...QQcmdZViewItem
R CA HHR is offline
Old 11-20-2007, 01:17 PM
solman98's Avatar
Just install monitors in your own headrests. It's actually very easy to do. These are the ones I put in my wife's MPV.
solman98 is offline
Old 11-20-2007, 01:21 PM
quest51210's Avatar
www.millionbuy.com
quest51210 is offline
Old 11-20-2007, 02:32 PM
I like those. We could put one in each car id we wanted!
How are they powered?
GDZHHR is offline
Old 11-20-2007, 05:35 PM
R CA HHR's Avatar
wires go down though the seat and I just tapped into the 12v power plug in the back of the center console. Remove the plastic inserts off the back of the seats and it all open and very easy to run wires. They can play two diffent dvds at then same time, one throught the radio and the other with the headphones. I would like to hook them up to the radio so I dont have to use the rf option so I could get better sound but I dont know how.
R CA HHR is offline
Old 11-20-2007, 07:19 PM
Thanks for the info, I think these will work out great for us.
GDZHHR is offline
Old 11-20-2007, 08:15 PM
Shootr's Avatar
Here's mine...
Just finished the install and was going to start a thread - but cool, here's one already.
Paid $375.00 on ebay for both, new leather headrests with dvd/monitor built in already. Fit well, easy to install, and each child has their own.
https://www.chevyhhr.net/gallery/showimage.php?i=10464
Shootr is offline
Old 11-20-2007, 09:07 PM
itschaboykenny's Avatar
Not quite sure how good they are but it's worth someone looking into for headrest monitors.
www.pyleaudio.com
Item # PL56PHRB
Headrest Pair with Built-in 5.6'' TFT-LCD Monitors (Black)
Price $360.19
*Pictured Below*
itschaboykenny is offline
Quick Reply: Will these LCD Headrests Fit?
