wiremagic 2006-08 hhr alarm/ remote start tech page
12 VOLTS
Red/black C3 plug on BCM in center console +
IGNITION
Yelloq Ignition switch harness or C4 plug on BCM +
ACCESSORY
Brown Ignition switch harness or C4 plug on BCM +
STARTER
SEE NOTES
TACH SIGNAL
Use a fuel injector
FUEL INJECTOR
Opposite from Pink At any injector on engine AC
LOCK
White In driver's kickpanel or C1 plug on BCM [General Motors 1-wire doorlock system]
UNLOCK
DOORPIN
SEE NOTES
TRUNK PIN
Orange/black C1 plug on BCM in center console -
TRUNK RELEASE
Tan C2 plug on BCM in center console - [All trunk release diagrams]
FACTORY ARM
With OEM remote only
FACTORY DISARM
BRAKESWITCH
Lt.blue At sitch above brake pedal +
PARKLIGHTS
Brown In driver's kickpanel or C1 plug on BCM +
HAND BRAKE
Lt.blue C1 plug on BCM in center console -
HORN
Tan Ignition switch or C2 plug on BCM -
CLUTCH SWITCH
Yellow At switch on clutch pedal bracket TYPE 1
REVERSE LIGHTS
Lt.green Under driver's side running board +
PASSLOCK DATA
White Ignition switch harness DATA
PASSLOCK GROUND
White/black Ignition switch harness -
Available Notes
Vehicle Notes
PLEASE NOTE: This vehicle is equipped with GM's PASSKEY 3 Immobilizer as well as a special version of GM's PASSLOCK 2 anti-theft system. The start function is controlled through the accessory wire and no starter wire is needed. Please refer to the SECURITY diagram before installing any remote start products.
Additional Notes
Personal Notes [Append a new note]
Available Diagrams
[All trunk release diagrams] All trunk release diagrams
[General Motors 1-wire doorlock system] General Motors 1-wire doorlock system
[New GM Hybrid Passlock/PASSKEY bypass] New GM Hybrid Passlock/PASSKEY bypass
Print page
Note: The information on this sheet is provided to you on an as is basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Autoland and/or any associated or unassociated individual or corporation who furnishes this document and/or software assumes absolutely no liability or responsibility whatsoever pertaining to the accuracy or currency of the information supplied. The installation in each and every case is the sole responsibility of the installer performing the work and Autoland and/or any associated or unassociated individual or corporation assumes no liability or responsibility whatsoever resulting from any type of installation, whether performed properly, improperly, or in any other way. The information supplied is a guide only.
©2006 Autoland All Rights Reserved
IGNITION
ACCESSORY
STARTER
SEE NOTES
TACH SIGNAL
Use a fuel injector
FUEL INJECTOR
LOCK
UNLOCK
DOORPIN
SEE NOTES
TRUNK PIN
TRUNK RELEASE
FACTORY ARM
FACTORY DISARM
BRAKESWITCH
PARKLIGHTS
HAND BRAKE
HORN
CLUTCH SWITCH
REVERSE LIGHTS
PASSLOCK DATA
PASSLOCK GROUND
Available Notes
Vehicle Notes
Additional Notes
Available Diagrams
Print page
HillsdaleHHR
02-21-2009 02:26 PM
