Wiring Diagram
Old 06-09-2009 | 08:32 PM
riveratx25's Avatar
Wiring Diagram
I've been searching long and hard on these forums and still can't find what I'm looking for. I'm wanting to hard wire my aftermarket stereo but can't find the wiring diagram to know what wires need to be connected. I have a 06 LS, no Onstar, no xm radio, just a plain oh single disk cd player. Can anyone help me out with this?
Old 06-10-2009 | 01:12 AM
prod's Avatar
the wires have been posted, not sure why it wouldnt show on a search.
EDIT: have a look at this thread: https://www.chevyhhr.net/forums/audio-video-17/instructions-install-aftermarket-amp-sub-2891/
The original wiring diagrams are no longer hosted on the same site though. Hopefully someone here has the .pdf saved?
Old 06-10-2009 | 09:19 AM
riveratx25's Avatar
Thanks for the reply. This post however was more towards an amp and subs. I'm looking for the wiring diagram for the headunit. And I did notice in a couple of thread the pdf file was no longer available too.
Old 06-10-2009 | 09:33 AM
ChevyMgr's Avatar
Give me the last 8 of your VIN so I can see what radio you have.
Old 06-10-2009 | 12:03 PM
riveratx25's Avatar
The last eight of the vin are 6S624248
Old 06-10-2009 | 01:41 PM
ChevyMgr's Avatar
Radio C1 (UW5)
Pin Wire Color Circuit No. Function
1 RD/WH 1140 Battery Positive Voltage
2 GY 8 Instrument Panel Lamp Dimmer Switch Signal
3 -- -- Not Used
4 D-GN 117 Right Front Speaker Output (-)
5 L-GN 200 Right Front Speaker Output (+)
6 GY 118 Left Front Speaker Output (-)
7 TN 201 Left Front Speaker Output (+)
8 BK/WH 651 Ground
9 D-GN 5060 Low Speed GMLAN Serial Data (Early Production)
9 D-GN/WH 5060 Low Speed GMLAN Serial Data (Late Production)
10 -- -- Not Used
11 D-BU 1796 Steering Wheel Control Signal (UK3)
12-14 -- -- Not Used
Radio C2 (UW5)
1 BN/WH 367 Remote Radio Left Audio Signal (+) (U2K)
2 D-GN/WH 368 Remote Radio Right Audio Signal (+) (U2K)
3 PK 314 Radio On Signal
4 D-BU 46 Right Rear Speaker Output (+)
5 L-BU 115 Right Rear Speaker Output (-)
6 BN 199 Left Rear Speaker Output (+)
7 YE 116 Left Rear Speaker Output (-)
8 PK/BK 2062 Cellular Telephone Voice Signal (UE1)
9 TN/WH 372 Audio Common (U2K)
10-13 -- -- Not Used
14 WH/BK 644 10-Volt Reference (UK3)
15 -- -- Not Used
16 OG/BK 2061 Cellular Telephone Voice Low Reference (UE1)
Old 06-10-2009 | 01:42 PM
ChevyMgr's Avatar
You also have an open recall on head impact protection.
Old 06-10-2009 | 04:41 PM
riveratx25's Avatar
Awsome. Thanks alot. This is exactly what I was looking for. And I'll definately look into that recall.
Old 07-05-2009 | 03:32 PM
Wooglin's Avatar
Hey ChevyMgr,
Could you possibly get mine too? I looked at the diagram above and now I've torn apart my dash to find the diagram above is not the same as the wiring colors in mine
I have an 06 LT, last 8 of the Vin are 6S516382
TIA,
Nick
Old 07-05-2009 | 04:43 PM
Originally Posted by Wooglin
Hey ChevyMgr,
TIA,
Nick
Submit your request in the following thread, probably get a faster response.
https://www.chevyhhr.net/forums/general-hhr-4/date-manufacture-4220/
Quick Reply: Wiring Diagram
