Wiring Diagram
Old 07-05-2009 | 05:15 PM
tooter1's Avatar
Originally Posted by riveratx25
I've been searching long and hard on these forums and still can't find what I'm looking for. I'm wanting to hard wire my aftermarket stereo but can't find the wiring diagram to know what wires need to be connected. I have a 06 LS, no Onstar, no xm radio, just a plain oh single disk cd player. Can anyone help me out with this?
I hope you aren't gonna splice into that harness. Just buy a module and keep your chimes and won't have to splice into the car harness.
Old 07-05-2009 | 05:36 PM
oneton's Avatar
Tooter1; It might be a little late that post is almost a month old!
Good try to save the harness from a chop job.
Old 07-06-2009 | 09:14 AM
ChevyMgr's Avatar
Radio C1 (UQ3)
Pin Wire Color Circuit No. Function
1 RD/WH 1140 Battery Positive Voltage
2 GY 8 Instrument Panel Lamps Dimmer Switch Signal
3 -- -- Not Used
4 L-GN 1948 Right Front Low Level Audio Signal (-)
5 L-GN/WH 512 Right Front Low Level Audio Signal (+)
6 D-GN 1947 Left Front Low Level Audio (-)
7 TN 511 Left Front Low Level Audio Signal (+)
8 BK/WH 651 Ground
9 D-GN 5060 Low Speed GMLAN Serial Data (Early Production)
D-GN/WH 5060 Low Speed GMLAN Serial Data (Late Production)
10 -- -- Not Used
11 D-BU 1796 Steering Wheel Control Signal (UK3)
12-14 -- -- Not Used
Radio C2 (UQ3)
1 BN/WH 367 Left Audio Signal (+) (U2K)
2 D-GN/WH 368 Right Audio Signal (+) (U2K)
3 PK 314 Radio On Signal
4 D-BU 546 Right Rear Low Level Audio Signal (+)
5 TN 1946 Right Rear Low Level Audio Signal (-)
6 BN/WH 599 Left Rear Low Level Audio Signal (+)
7 BN 1999 Left Rear Low Level Audio Signal (-)
8 PK/BK 2062 Cellular Telephone Voice Signal (UE1)
9 TN/WH 372 Audio Common (U2K)
10-13 -- -- Not Used
14 WH/BK 644 10-Volt Reference (UK3)
15 L-GN 1011 Remote Radio Control Signal
16 OG/BK 2061 Cellular Telephone Voice Low Reference (UE1)
Old 05-23-2010 | 01:28 PM
Rogoflap's Avatar
Chevy Mgr,
I have a question about the wireing diagram(s) I see above. I notieced there is a
Would this be a place where I would see a push of one of the radio steering wheel buttons. (Volume Up?)
Would all the radio steering wheel buttons be on this wire?
How are the signals being passed by resistance differences along this wire?
Reason I as, I have the GMOS-LAN-04. The harness currently doesn't have a wire in the plug at this location, so it isn't passing this information along, but I would like to add an additional wire and use it to pass along the steering wheel buttons presses.
There is a device that can capture this resistance differences when each button is pressed. I would like to use this with my Carputer.
Any suggestions on how I could pick up this signal if the above is not correct? I am trying to not make an cuts / splices in the original wiring harness.
Roger
Old 07-16-2016 | 07:28 PM
leothegecko's Avatar
If anyone is wondering where to tap into when installing a line out converter for the Lt hhr with stock pioneer speakers I would recomend using the low level audio signal from either the front 2 speakers or rear 2 speakers.
Old 10-06-2018 | 11:12 PM
Cody Stewart's Avatar
Is it the same for a 2009 ls last 6 is 577278
Originally Posted by ChevyMgr
Give me the last 8 of your VIN so I can see what radio you have.
Old 10-07-2018 | 04:53 AM
Check the date on this thread. It's from over 9 years ago.
Besides, ChevyMgr is not on the site anymore.
Old 10-07-2018 | 08:02 AM
Closing this thread - thanks FMG.
Mercury
11-22-2019 09:13 PM
Unclesams_SS
11-20-2016 08:25 AM
hvrod
02-07-2014 02:54 PM
ROMEO_Rocks
12-16-2010 01:31 PM
cannuck
06-27-2009 10:50 PM
Quick Reply: Wiring Diagram
