Wiring for Pioneer radio into 09 HHR
Before I was officially a "member" here, I started posting a question, but then lost my draft when I went through the membership enrollment process, so here goes...
I have a 2009 HHR which I am putting a Pioneer FH-S51BT radio into. My stock radio had two plugs, one ostensibly for the front speakers and the other for the rear speakers. The Pioneer only has one. I haven't been able to find a correct plug configuration for the stock units to transfer the the colors appropriately to the new input. I did find one reply on here that had almost all of the same colored wires that I have have, but it was for a 2007 model (if memory serves me correctly). I now know the correct colors for the respective speakers, but have a couple of extra wires not mentioned in the post I was replying too.
Don't ask me which post it was in, since I am totally crossed up now, but I had saved the above quote to MS Word to print out.
My car has NO pink wire in the harness (which I don't need anyway), but I do have a red and a white/black extra on the rear speaker plug and dark blue and green/white wires on the front plug.
Any ideas and thanks to the fellow (who shall remain unknown to me at this point) who posted the above wire color codes.
Thanks in advance for any and all helpful suggestions.
Blessings,
George, aka, TheShadeTreeFixitMan
https://www.youtube.com/user/Busia1949?feature=mhum
Here is the 2007 hhr wire diagram:
Car Radio Constant 12v+ Wire: Red/White
Car Radio Switched 12v+ Wire: you can catch accesory in the large harness below the fuse box. it is a heavy guage Pink (10g or 12g) wire.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Inside the drivers side rear quarter panel.
Front Speakers Size: 6.5
Front Speakers Location: door
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: 6.5
Rear Speakers Location: door
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Blessings,
Last edited by TheShadeTreeFixitMan; 02-03-2020 at 08:04 PM. Reason: wrong formatting
Welcome to the site, you will need an interface have a look at Crutchfield
https://www.crutchfield.com/m_266150/Car-Stereos.html
All I saw at the site you sent me to was adapter plugs to use with the original harness. The directions from the Pioneer radio don't say anything about a separate interface either.
BTW, the original factory radio was a Delphi unit.
The best way is to use the available wiring adapters and not cut into the existing harness.
(after noting your user name, maybe cut and splice is really what you want to try. )
There must be a pink wire it. If you intend to use the stock antenna you need it because it powers the antenna amp.
Since you couldn't find any of the posted diagrams here is the 2009 w/o amp.
Note there is no switched 12V, that is handled by the serial data line. (internal SSR)
