XM Radio
Old 12-20-2007, 12:48 PM
Sparky's Avatar
XM Radio
I purchased a 08 HHR 2LT in November. XM radio was not on window sticker and I don't have XM. On the rear roof I have a XM antenna base. There is a hole in the base to secure an antenna. I'm just wondering why this HHR came with the antenna base.
Sparky is offline
Old 12-20-2007, 01:06 PM
Snoopy's Avatar
That is curious ???!!!!! And you say, you DO NOT have XM on the stciker or indiated on the radio. Did you buy the vehicle new from a GM dealer? Maybe they can answer it.
If you purchased used...maybe its a rental with a GPS antenna. I noticed several in rental fleets with the GPS antenna in the back.
Snoopy is offline
Old 12-20-2007, 01:45 PM
crazybob's Avatar
I'm guessing you have OnStar? If so, the hole in the base is for your (missing) OnStar antenna.
crazybob is offline
Old 12-20-2007, 01:48 PM
an08HHR's Avatar
OnStar is a standard item on the 08's
an08HHR is offline
Old 12-20-2007, 02:16 PM
TomR00's Avatar
Yea, the OnStar was standard on my 08, but the XM shows up as an option @ $200 on the window sticker.
TomR
TomR00 is offline
Old 12-20-2007, 02:33 PM
Sparky's Avatar
I DO NOT have XM on the sticker or indicated on the radio. I bought the vehicle new from a GM dealer and received the GMS employee discount.
Sparky is offline
Old 12-20-2007, 02:36 PM
Sparky's Avatar
The owners manual states that the XM radio antenna is located at the rear of the roof. I have OnStar.
Sparky is offline
Old 12-20-2007, 02:46 PM
Snoopy's Avatar
To the dealer....you should go
Snoopy is offline
Old 12-20-2007, 08:39 PM
crazybob's Avatar
AND the OnStar antenna is at the rear also. But what do I know. I've only owned my car for 2 years now... Again, that hole in the antenna base is for the OnStar antenna. The base would be the XM antenna if you had XM.
Your OnStar may be working, just not very well without the mast.
crazybob is offline
Old 12-21-2007, 01:41 PM
Snoopy's Avatar
Sparky......
Found this in GM Tech Info. It appears you have this antenna and the dealer didn't provide (don't know if they routinely do) the complete antenna.
Hope this helps...
A new OnStar or combination OnStar/XM antenna is being used on a wide variety of vehicles in 2006.
If the improper procedure is used to remove the mast, the base may be broken or the mast may be gouged.
A hidden locking tab must be depressed to remove the mast from the antenna base (fig. 9 and 10). Insert a small screwdriver between the mast and the base to depress the locking tab while turning the mast to unthread it from the base.
- Thanks to Jim Hughes
Snoopy is offline
Quick Reply: XM Radio
