bagged HHRs click here please!!
I'm running my airline this weekend under my HHR, and when my slim air tank comes in, im getting my friend to swap out the front stock springs/coils with my aftermarket ones. at that point the front will be bagged, i just want to run the line now so its all in place, so we can just swap out the front suspension and hook it up.
im mounting the tank inside the cargo area, but the valves will be outside. ill have 8 valves (FBSS). How many runs of line do i need from the tank itself, how many runs to each wheel well, etc. ?
wheres a good place to mount valves/run line? anything else i need to do? also, is it safe to just zip-tie the line to the chassis somehow?
Lots of looks...I think there are only maybe 2 or 3 folks on here that have their HHR's bagged...lunchbox is the only member I think that is active...Mike will have to chime in. I know nothing about airbag suspensions, but I'm leaning toward one myself. Good luck.
You hit it right on the head chef.
Lunchbox is the guy to ask about bagged suspension, his HHR sits so low he can rear end an ant.
Give this thread a read, and shoot lunchbox a PM, I'm sure he'd be happy to answer your questions.
https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/airbag-airspring-questions-41286/#post649908
