Brake Questions
Old 04-21-2012 | 11:41 PM
I agree Mike-
Interesting I think is that the rear HHR brakes shoes
are the same & interchangable..
No Leading shoe or trailing shoe, like most older rides have.
& of course the adjuster being up top, just under the wheel cylinder..
I miss the quik spring retainers.
So the '37 has bolts & not wheel studs, interesting..
Old 04-21-2012 | 11:54 PM
Yup, lug bolts and not lug nuts, Chevy vacillated back and forth a couple of times in the 30's between the two styles. Honestly I'd like to have studs and lug nuts when heaving one of those "2 Ton" wheels into place, dang things are heavy.
Don't take this as a knock against Michelle's new Fiat 500C, but there is enough steel in one of those wheels to make a whole Fiat, or so it seems.
I do miss the Qwik-Spring retainers too, probably managed to save a few pennies per unit by losing them, and no real need for different shoes as in the days of old.
The rear drums on the HHR are "Self Energizing" to a point, but the brakes on the Carryall are true Self Energizing brakes, they stop hard and true with no need for power assistance...its all in the leverage principal used to pull the shoes into the drums progressively harder depending on pedal pressure. When you drive it you can get a feel of just how well the engineers back then compensated for the lack of power assistance, do things just right, and you never need it.
Old 04-22-2012 | 12:13 AM
Wifeys former '96 BMW Z-3 has lug bolts..Always was fun doing tire rotations..
Easy to get spoiled just hanging a rim on studs..
Quite a few of my early GM & Chevys had No Power brakes, & stopped fine also..
I'm sure those '37 drums dwarf our HHR drums in size..
Old 04-22-2012 | 12:35 AM
11" front and rear on the 1/2 ton trucks and the Carryalls, you do not want to drop one on your foot, trust me.
I have a trick to get the rims on without too much drama, I took an old unusable lug bolt and machined the threads off.
When I get to the point of putting a wheel back on...its just a matter of heaving it up into place and sticking the "blind" lug bolt in a hole to keep it in place long enough to get a few proper lug bolts started.
Old 05-04-2012 | 08:39 AM
swerv0428's Avatar
Alright, so I got to look at the drums this morning. I cleaned the brakes out with brake clean. The driver side drum was adjusted about perfect, the passenger side was very loose. So I adjusted it and put it all back together. The pedal is a little firmer but definently better. Thanks to everyone for the help. Next is new front brakes since the rears are good now.
Old 05-04-2012 | 11:44 AM
  #26
Old Lar's Avatar
My 59 Plymouth had lug bolts. I had to replace one of the hubs and got a right side for the left and the bolts were always working their way loose. At that time I didn't realize that there was a difference between a right and legt hub. It was a PITA to "bolt" on wheels.
Old 05-04-2012 | 11:14 PM
  #27
Yep, Plymouth did have Left Hand & Right hand threads..(learned that the hard way also).. Strange but true..
Not sure how long that lasted..I know in the later 60's Plymouth still had Left & right threads, but went to studs..
I used to use a tapered drift pin to locate the hole-position when putting on a wheel on the Z-3 ...
Rjj
10-22-2017 08:56 AM
jerseyjim
Maintenance and Upkeep
17
12-09-2013 01:32 PM
yosemitrsam
22
08-28-2013 07:13 PM
American & Proud
03-27-2012 09:51 AM
RodzHHRss
03-27-2009 06:29 AM
Quick Reply: Brake Questions
