Brake squeal
Brake squeal
I have just installed the new nickel plated rotors and new pads. I am getting some sqealling out of both sides. I have about 50 miles on them so far and have gone pretty easy on them as the break in instructions direct. Any idea's?
Joe
Joe
You might just need to heat them up alittle bit. I have just the factory brakes and they were doing the same thing, so insted of going to the shop I just went down the highway and slightly pushed on the brakes with my foot on the gas. No more noise from mine.
Joe
Joe
I wish I could offer a solution, but it's one of the tradeoffs of having nice shiny rotors. I now have 400-miles on mine and they are fully broken in. Braking noise is gone away, and braking power is much increased over stock. I have noticed the SP "low dust" pads are leaving more residue than the stock pads did. Spoke with SP about this and they told me this is often the case with newer vehicles; the stock organic material pads produce less dust, but have poorer gripping power. The SP pads are semi-metallic; more stopping power and more dust (than stock).
Hope it helps,
OK, I now have about 325 miles on the HHR. The squeeling has disappeared!
The brakes grab well and look great!
The only negetives are more brake dust and a wirring sound(which I new I would have because of past experience with drilled, sculpted rotors). The sound is not really bad, just different. And with my sub banging who hears it anyway!
Joe
Joe
