Cobalt SS SC front springs
Old 02-21-2011 | 08:59 AM
B1GP1MP1N's Avatar
Originally Posted by prod
I noticed this when I had the ss/sc springs. The turns seem a bit crisper with the CM springs I have now, which are a little higher in the rear like the pedders.
Did you have any alignment issues after installing these CM springs? My HHR is pulling to the right something fierce... I had a local shop do an alignment on Saturday and it is still pulling to the right. Maybe just a crappy alignment job but I am really concerned about this. Any ideas from anyone would be greatly appreciated.
Thanks.
Old 02-21-2011 | 11:25 AM
PhoS's Avatar
Take it back and make them redo it , all that you should have needed was a toe adjustment at most. Tell them to do it right this time.
Old 02-21-2011 | 01:33 PM
prod's Avatar
Thanks.
I think its a good idea to get an alignment after puttin on lowering springs, and my right front did need a bit of toe adjustment. Not sure if that was a result of the springs though.
Definitely get the alignment redone. They should have road tested it at the time.
Old 02-22-2011 | 09:54 AM
B1GP1MP1N's Avatar
I took this back to the place I got the alignment done and they claim it's in spec and there is some other problem with the car. I am thinking that the shop where I had the springs installed may have jacked something up. It pulls to the right so bad I have to hold the wheel to keep from drifting off the road. Anyone have any ideas what could have been installed incorrectly or damaged during the spring install?
Shanes0406
26
12-18-2015 10:11 AM
retrolled
02-11-2014 10:46 AM
