Coil spring lowering kit?
Old 03-13-2009, 08:58 AM
06Daytona's Avatar
Anyone know anything about these coil spring kits? Do you think that they would really drop 3"?
http://www.jcwhitney.com/HELLWIG-COI...3409_10101.jcw
06Daytona is offline
Old 03-13-2009, 10:34 AM
mrkil's Avatar
garbage!
those will destroy the handling of your hhr. it's almost as bad as cutting your springs.
save your money and do it right
https://www.chevyhhr.net/forums/deleted-threads-41/gold-line-gen-1-lowering-springs-22411/
mrkil is offline
Old 03-13-2009, 10:38 AM
DLVRNIT's Avatar
:twothumbs^^^ x2 ^^^:twothumbs
DLVRNIT is offline
Old 03-13-2009, 10:52 AM
LTSport08's Avatar
X3!
LTSport08 is offline
Old 03-13-2009, 11:02 AM
catdaddy137's Avatar
for $10 maybe
for $45.95 , no way!!! you can get cobalt springs for that price , they won't give you 3ins, but i doubt if those things will either.
catdaddy137 is offline
Old 03-13-2009, 12:29 PM
masterchief1112's Avatar
with those maybe an inch. and tlak about dangerous. if that were to break your suspension would shoot back to stock ride height and i think would break something.
masterchief1112 is offline
Old 03-19-2009, 03:40 PM
Lee3333's Avatar
Lower springs are not just lower-the spring rate is changed. Years ago people (myself included) used to cut off a few coils, but that is not the right way to do it.
I recall JCWhitney selling little metal wedges that you would insert inbetween the coils then twist, with the intent being to raise the car. Worked great until you hit a bump and the springs expanded, then they would fall out!
Keep in mind that when you lower the coils in the back, they may fall out when you put your car on a lift. This happened to me with the levelling springs. I am eagerly awaiting some new shortened KYB shocks that will prevent this from happening. But, they do cost twice as much as the standard shocks.
Lee3333 is offline
Old 04-09-2009, 04:33 PM
Tikker's Avatar
Unhappy
Are the KYB shortened units the only thing available?
I'm looking at the shocks as being my "rattle" problem.
Tikker is offline
Old 04-16-2009, 10:11 AM
Lee3333's Avatar
The KYB are the only ones I found that are made to fit and shortened. I began looking into a custom shock, but that would mean not only getting the measurements of full extension and contraction, but also the dampening rate. The only other cure would be using limiting straps, but then you have the problem of them banging around.
Lee3333 is offline
Old 04-16-2009, 03:15 PM
Tikker's Avatar
Question Lee3333
Do you have the "rattle" problem?
Please let me know if the KYB modified shocks cures that issue.
Tikker is offline
Quick Reply: Coil spring lowering kit?
