Cold weather sqeaking is back...
Old 02-28-2011 | 05:43 PM
  #31
Krusty's Avatar
OK....before you go spending lots of cash chasing down suspension noise, check the plastic compartments behind the rear seats!!! Mine had become loose and they mimicked a suspension problem to a Tee!!! Its worse when the cold makes the plastic more rigid. If you can rock the boxes for and aft, they're loose. There are 4 bolts that become visible once you remove the rear cover and spare tire cover. You can also test this theory by releasing a rear seat and then sandwiching a folded towel between the seatback and the boxes.
Old 02-28-2011 | 06:00 PM
  #32
nacademus's Avatar
Have someone else drive your car for the first 5-10 mins lol
Old 04-05-2024 | 04:54 PM
  #33
Cougarboy's Avatar
Cold Weather Squeaking
My HHR would squeak when I drove it after startup. This was particularly bad during cold weather. The sound would go away after warm up.
The problem was worn out lower control arms. I had them replaced and the noise stopped. The car had over 110K on it so this may not help the owner of a lower mileage car.
Dennis
Houston
Old 04-05-2024 | 05:17 PM
  #34
I’m going to leave this one with the 13 year old thread as it is pertaining to the original cold start noises.
Tyler Harvey
06-23-2011 04:21 PM
ouhockeyplayer
29
03-09-2010 09:16 PM
Big Rad
12-28-2009 11:02 AM
fastsuv
02-12-2008 11:57 AM
454Taylor
03-17-2007 01:34 PM
