Eibach or Progress?
Originally Posted by JOEK86
Other than the small difference in drop, about 1/2", are there any advantage or disadvantages to either? Experiences and thoughts please............
Joe
Joe
Originally Posted by HHR PNOY
I have 7.5's with 45 offset...no rub.
Positive offset is the reverse of normal wheel "offset."
Most FWD vehicles have positive offset wheels.
Hi Joe, I ran the Gold-Lines with my stock wheels for 6-months with no issues, and several others (with both 16 & 17's), have done so also. You just need to make sure that if you are buying new aftermarket wheels, they have the proper offset to stay tucked.
Hope it helps,
Hope it helps,
Thanks Mike, I just put an order through to you for the GL springs, shims, camber and sway bar! I am going to try my after market wheels, if they rub I will go back to stock until I can find some AM wheels with spec's that will work.
Joe
Joe
Joe
Joe
