Energy Suspension sway bar bushing question
Old 11-20-2014 | 05:40 PM
Snoopy's Avatar
Question for the members who installed the above bushings that you grease........
I believe one of the members mentioned that he replaced the straight zerk with a 90 degree. Is this necessary? Can the straight zerk be reached, to do the greasing, RELATIVELY easy without this replacement? I have a hoist hopefully to simplify the install and the greasing maintenance..
I purchased the greasable bushings some time ago and they have been sitting on my parts shelf. Decided to install them BUT, right now I'm laid up with a very bad back injury (minor surgery coming this Tuesday) so I can't get the car on the hoist to do any work or to see about clearance.
Any info would be appreciated so I can prepare, if necessary, for the install.
Hope to be back to "active" in about a week.
Old 11-20-2014 | 06:26 PM
VinceP's Avatar
I originally installed the straight zerks but at first try to grease them I couldnt reach them. Replaced with 90's. Use the 90's if you have them. If not, get them. Makes the job much easier.
Old 11-20-2014 | 06:33 PM
90's are way easier, you can reach up to the straights if you have a flexhose on your grease gun but it is a pain!
Old 11-20-2014 | 10:11 PM
x2 - but I used the straight ones, and can reach them ok with little difficulty. Depends on the grease gun to a degree.
Old 11-21-2014 | 03:04 PM
Snoopy's Avatar
Ok, thanks a bunch guys.
I have an air pressure grease gun that has a flexible hose. But the metal female connector portion is about an inch long and not flexible, so I guess I'll purchase the 90 degree zerk.
A further question.....I'm told the split in the bushing itself faces to the rear. Which way do you recommend to position the zerk....front, rear, angled.
Oh, and I guess this is stupid but, there is 2 fittings......each angled in the same direction?
Hate to be a nuisance but I can't get out and look....sorry.
Old 11-21-2014 | 08:33 PM
I angled mine to face out toward the wheel so I can reach it from the side, I don't have a lift just a jack and stands for LOF time!
Old 11-21-2014 | 11:23 PM
alexrckid's Avatar
right off the bat i put 90's in my energy suspension pieces. found that the zerks wanted to reposition themselves angle wise..so, went one step further. after positioning the 90's so i could get to them, i glued them in place with some JB WELD. have since lubed the bushings many times and the zerks have not moved at all.....makes a PITA jo a bit easier when you dont have to fight with zerks that wont stay put..
Old 11-22-2014 | 02:50 PM
Snoopy's Avatar
Thanks guys for the responses.
I purchased some 90 degree zerk fittings yesterday. All ready to start the install .........when I'm physically ready
Old 11-22-2014 | 06:18 PM
No rush it takes te to recover! So, take it easy and don't rush the recovery!
Old 11-27-2014 | 02:52 PM
bbcdon's Avatar
I am a newbie, so excuse my lack of knowledge. I am going to have the front suspension of my 09 LT gone through, and the first question is regarding the size of the front sway bar bushings. I see that they come in 25mm, and also 26 mm sizes. How does one know which size to use?
