front caliper help
Old 03-06-2010 | 01:44 PM
alg's Avatar
alg
front caliper help
I replaced the front pads and rotors and noticed that the rubber around one caliper piston had a small crack. There was no fluid present.
Does anyone know if fluid will leak out of the caliper if the outer rubber seal has a crack?
In older American cars, this rubber was usually a 'dust seal', and it had no fluid behind it. But I can't tell from the limited diagrams available.
Thanks in advance for any info you can provide.
Old 03-06-2010 | 08:28 PM
got2boostit2's Avatar
It's a dust shield. You could replace it without caliper disassembly.
hurst2001
04-03-2015 06:04 AM
jay loukakis
12-18-2010 03:57 PM
DBHHRLT
01-25-2009 05:05 PM
R CA HHR
05-31-2008 01:58 AM
