Getting ready to order MOOG front sways.
Old 08-02-2012, 07:46 PM
Augmented78's Avatar
I'm going to place my order for the front sways tomorrow and wanted to make sure I get evrything right. Are the sway bars universal? That is, does one fit both left and right side? And, is the proper part # K750012?
Augmented78 is offline
Old 08-02-2012, 08:05 PM
THE BATMAN's Avatar
Stabilizer links , That is the Moog part # i put on my SS . Have fun getting off the originals , P.I.T.A.
There are threads for the easiest way to replace them on this site.
THE BATMAN is offline
Old 08-02-2012, 08:34 PM
08SSREDHHR's Avatar
Cut the old ones off makes things alot easier. lol yes I believe their universal aswell, I had them on my cobalt and dont remember them being different.
08SSREDHHR is offline
Old 08-02-2012, 08:44 PM
If only I had bolt cutters lol
Old 08-02-2012, 08:56 PM
Ha Ha I talked my dealer into installing the moogs instead of the junk, it was easy..
SS fan is offline
Old 08-02-2012, 10:51 PM
A couple end joints on my original links were so badly worn, I twisted then right off the ball at each end. Vice grips then made it easy to get the ball studs off.
whopper is offline
Old 08-02-2012, 11:30 PM
IgottaWoody's Avatar
be careful of the length..there 2 different sizes(length)..though it wont really hurt either way as long as your not a trackster
IgottaWoody is offline
Old 08-02-2012, 11:48 PM
prince_bigd's Avatar
Btw welcome to the site augmented. It's nice to see a fellow KY member. I'm in main eastern KY, where are you located?
prince_bigd is offline
Old 08-03-2012, 06:13 AM
Thanks! I've been around for almost month, having picked up my HHR on 7/16. I'm located in the Ashland area.
What is the OE spec length for a 2010 LS?
Old 08-03-2012, 07:06 AM
wmsburghhr's Avatar
The Moog K750012 are the shorter type (approx 10 inches) some HHR have some close to 12 inches long so measure yours before buying. I just replaced mine a week ago and had no big problems. The top nut came right off with my impact gun. Bottom shaft spun but you can grab the inside of the stud with an open end wrench or vise gripes. right side is same a left. Top and bottom nuts are 18MM (FYI) Have both sides of the front end up in the air to take the load off the links.
wmsburghhr is offline
Quick Reply: Getting ready to order MOOG front sways.
