Heavy hauling
Old 03-22-2013 | 05:23 PM
kkavmann69's Avatar
Question Heavy hauling
I've got a 2007 LS and I haul 500lbs or more everyday for work. I have searched throughout the threads and haven't found one that mentions springs that could hold that kind of weight. Perhaps I missed it. I would like to either keep the same ride height or mabey a little higher. If anyone has a suggestion I would appreciate it.
Old 03-22-2013 | 07:18 PM
Look at Rockauto for "progressive" springs. They are reasonably priced at around $50 a pair.
Old 03-23-2013 | 02:33 AM
prod's Avatar
I have a pair of canuck motorsports springs that worked well, I had a couple trips with 900lbs of laminate flooring in the back, it would almost bottom out over large bumps, but it was better than stock springs. Stiffer springs meant a bit harsher ride without the extra weight in the back. I may be taking them off soon, if you are interested let me know.
Old 03-23-2013 | 10:39 AM
IgottaWoody's Avatar
just add air bags to the rear springs..that way when your empty it can be set back to normal...less then 100$..no mods..just jack, slip bag inside (thru coils) spring..add lines and done..I have my lines terminated behind the fuel door
Old 03-23-2013 | 10:55 AM
kkavmann69's Avatar
Thanks for all the information. I'll check these options out and let you know which one I go with.
Old 03-23-2013 | 11:04 AM
kkavmann69's Avatar
Woody. Where did you go to get your air bags?
Old 03-23-2013 | 12:29 PM
VinceP's Avatar
Not Woody but he may be talking about the ones from Summit Racing.
Look up Airlift 60776
Hope this helps.
Old 03-23-2013 | 01:26 PM
kkavmann69's Avatar
It did Vince. Thank you. Woody, How long have you had them in and how are they working for you?
Old 03-31-2013 | 07:17 PM
somehow missed this..they have been in for 4 years and no problems..I ordered from JCW only because of price, I like em because they operate on low pressure..5 to 20 lbs makes all the difference. Between hauling a trailered bike..St Bernards and camping gear...a full size roll around tool box, I have to say they done good
Old 04-01-2013 | 11:50 AM
solman98's Avatar
Hope this helps.
I'll add a 3rd for air bags.
