KYB's installed
KYB's installed
Got out this morning and installed a new set of KYB front struts along with some new strut mounts and rear KYB shocks. What a difference in ride now. I knew I needed to replace them but I guess you just get used to it driving on a daily basis. Rotated tires and adjusted rear brakes while I was under her. Feels like a different car. I guess the clunks I was getting were strut related because on the test ride it was GONE!
Buying from on line vendors sure helps save some $ too.
Thanks. It does feel like a different car. Feels almost new again. Going on a trip to Corpus Christi TX tomorrow for a few days so it will be a nicer ride down. I will have the alignment checked when I get back just in case. I know I have a front wheel bearing starting to make some noise so I guess I will have the dealer do an alignment when the replace the wheel bearing under warranty.
Glad to see someone went with the KYB's!... Where they pretty easy to do?
I am about to order the parts to do my as well and have never done struts before but have all the tools...
Did you replace stops, boots etc?.. About how long did it take?
I am getting all those annoying clunks and thunks now, 67k, so I figure its about time...
Update!
Every since I installed the new KYB struts I would get what would sound like a grinding sound every now and again when I would turn. I pulled the struts off and disassembled from the springs and sure enough there has been contact on top. Not from the strut but from the top strut plate and the strut mount. Upon investigating it looks like I had the top plate 180 degree from where it should have been.
Re-assembled last sunday and have not heard the noise again. It has been a week so I think she is good to go. Obviously I did not realize that they could be put on incorrectly or I would have been more careful.
The other thing I did while I had the front end apart was install new brake hardware. The little metal pieces that the front pads sit in and the boots where the caliper bolts go through. Doing this and putting new grease in the boots and the proper lube on the pad stays make a difference in the brake feel. Well worth the $12.
