Leveling dilemma
Old 12-23-2012, 02:16 PM
Dracos's Avatar
Originally Posted by 07azhhr
Look at Fire's first pic. That is just dropping the rear. Now look at Larry's pic. That is the Eibachs front and rear. Notice when you drop the whole car it sits level with the Eibachs. Their rear is stated as the same amount you say you need to be even with the front. If that is the case then perhaps something is wrong or has been altered already with your suspension.
Fire's first pic is dropped just in the rear (more than 2", iirc) and looks odd, while his pic in #8 shows his corrected stance with the 4 corner drop he obviously originally intended.
I just want to even out the gaps front and rear. All the 4 piece lowering springs drop the rear more than the front, resulting in leveling and lowering.
Dracos is offline
Old 12-23-2012, 02:22 PM
07azhhr's Avatar
If you only want the rear down a tad then you have but one choice. Get the cobalt springs and be done with it.
I used Fires pic as an example of what will happen even though the car looks level look at the gaps.
Larry's pic shows that the gaps are even and the car is level. Again if you have no intension of lowering the front then you have but one option and that is it.
07azhhr is offline
Old 12-23-2012, 02:25 PM
Dracos's Avatar
Originally Posted by panelmoxie
I have found that if you put 6 cases of double edge tape in the far back you will be level.
What about 6 cases of something more useful, like beer?
Dracos is offline
Old 12-23-2012, 02:48 PM
Another fwiw. My car on the full set of Pedders measures :ground to fender.
front:26"
rear :26 1/2"
The side skirt only measures about 1/8" rise from front to back.
These measurements are with the redesigned Pedders rear springs which are a 1/4" lower than the original Pedders.
firemangeorge is offline
Old 12-23-2012, 06:12 PM
HipHotRod's Avatar
Confirmed they are softer 'fo sho.
Originally Posted by sleeper
I've been running the SS/TC rear springs for years now.. The drop is 1-1/4"
(after settling).. Very Pleased. & I have FE3 also, these were a good match.
The SS/SC drop 1-1/2" but are SOFT.
They are/were. As I mentioned, the car tended to squat even when empty when I accelerated hard. Seeing how it's a front drive, soft springs definately were the culprit.
HipHotRod is offline
alexrckid
03-22-2015 07:28 PM
Slick61
03-03-2012 12:30 AM
FLBOIZ13
01-12-2010 03:46 PM
waloupis
01-11-2008 09:54 PM
the_dogs-bollocks
04-30-2007 05:27 PM
Quick Reply: Leveling dilemma
