Lower control arm rear bushing
Old 03-06-2024, 08:06 PM
Mookie1's Avatar
So I’m trying to replace the worn lower control arms. The rear subframe bolt is loose from the cage nut but it’s siezed to the control arm bushing sleeve. Any ideas to getting is loose from the sleeve bushing I’ve tried vice grips to no success.
Mookie1 is offline
Old 03-06-2024, 09:05 PM
Torches and saws come to mind. Maybe an overnight soak with a good penetrating solvent like Kroil.
donbrew is offline
Old 03-07-2024, 06:08 AM
Sawzall and cut the bolt.
Oldblue is offline
Old 03-07-2024, 06:49 AM
Mookie1's Avatar
I soaked it for days before starting with kroil never stat a job without it. Well time to break out the torch’s and saws all.
Mookie1 is offline
Old 03-07-2024, 06:59 AM
https://www.chevyhhr.net/forums/intr...-62087/page12/
It’s an experience!
Oldblue is offline
Old 03-07-2024, 09:40 AM
fastsuv's Avatar
Yep.
Been there, done that.
Cut it at the top side with the sawzall (use as short a blade as possible to avoid hitting the end on other frame parts and destroying the blade by kinking it).
Grind off the bolt head at the bottom to avoid having to sawzall the bolt at the bottom also. Its harder to sawzall at the bottom because the bottom support has sides that are bent up slightly.
Steve
fastsuv is offline
Old 03-08-2024, 03:22 PM
Mookie1's Avatar
What replacement bolts can I use any grade 8 ?
Mookie1 is offline
Old 03-08-2024, 03:42 PM
Why not go to a GM dealer parts department?
They are metric. So there is no "grade 8".
donbrew is offline
Old 03-08-2024, 04:25 PM
Engine Cradle Bolt (Front)
Part Number: 11589009
Supersession(s): 11518871
RJ_RS_SS_350 is offline
Old 03-08-2024, 04:55 PM
Mookie1's Avatar
Went to dealer discontinued.
Mookie1 is offline
Quick Reply: Lower control arm rear bushing
