Lowering Question on 20's
Old 01-24-2007 | 06:46 AM
giant96's Avatar
Would the Eibach kit work with 225/35/20 tires? The Wheels are 5 x110, 7.5 wide, 42mm offset American racing Casino's. I want a 35 series tire for a little extra meat and I know the goldlines would def not work but would the Eibachs be ok??
Old 02-07-2007 | 01:55 PM
Ern's Avatar
Ern
bump becuase I wouldnt mind knowing.
Old 02-07-2007 | 02:22 PM
O6ChevyHHR's Avatar
i think you would be okay, thats almost the same setup I was going to go with.
Old 02-07-2007 | 07:52 PM
en0oNmAI's Avatar
You should definately be all right. Only rubbing you might experience is from really hard dips and bumps. You may to roll the rear fenders slightly to accomodate the larger tires. Its a very simple task that one can do in the driveway with nothing more than a WOODEN baseball bat!
Old 02-09-2007 | 07:37 PM
Ern's Avatar
Ern
What about a 235/35/20 on a 7.5 inch rim
Old 02-09-2007 | 08:44 PM
O6ChevyHHR's Avatar
7.5 you will be fine whats the offset?
Old 02-10-2007 | 11:32 AM
Ern's Avatar
Ern
42 offset but im just wondering for a 7.5 inch rim if thats a good size meaty tire.
Old 02-10-2007 | 11:43 AM
I didn't go to 20's, but I did go to 18's 7.5 and that's a pretty wide tire. I'm real happy.
Old 02-10-2007 | 12:53 PM
O6ChevyHHR's Avatar
If you want looks go for 20s if you want a good ride and looks go with 18s. ..
Old 02-10-2007 | 12:55 PM
How many cars have you owned, much less one with 18's or 20's?
Quick Reply: Lowering Question on 20's
