Pedders eXtreme XA coilovers review
The install was a piece of cake. I wnt ahead and replaced the crappy stock sway bar end links with Moog end links (K750428). I ordered these online since none of my local parts stores carried them in stock.
The install was a piece of cake front and rear. I encountered no problems and the Pedders bits are, as always, very high quality.
I set the firmness 9 clicks from soft on front and rear. It is still a stiff ride, now I just need to adjust the height to where I want it to be.
Since I will be taking the wheels off this weekend to get the height adjusted I will snap some pictures at that time.. I was so engrossed in the install that I didn't even think about taking pictures!
Had problem with Pedders front springs coil binding. contacted Deb, and ended up getting a set of XA coilovers, for $300.00.
Did'nt get any install pics., but here is the XA's right before install.
I run 12 clicks frt. and 15 clicks rear, around town. 21 clicks frt. and 19 rear when I autocross. Makes the SS a hauling a-- slot car. I run 3 degrees neg. camber on frt. "Moon"
chefhhr
7
04-11-2014 08:24 AM
moonsign
12
01-25-2013 11:26 AM
