rear disc brake kits?
This is what HVrod said when i asked him bout it......
all parts from the GM dealer.. roughly about $1300-00 in all parts. One major part/s that you need is the adapter fittings for rerouting of the brake lines.. and the new lines.
Prices I stated were for all new GM parts....
You need an axle, emergency brake cables, disc, pads, calipers, new brake lines and fittings, dust shields..
The harness adapted to the new axle great, even with the ABS sensor...
(again this way you are using all GM parts mainly)..
There are kits by other vendors for approx. the same price.. but you do get 2 - 4 piston calipers and have to use 17inch min. wheels with theres...
I'm using 16inch rims/tires with my setup...
Hydraulic pressure is fine...
Heres some pics to renew your interests...
