Rear spring insulator.
Mine is quitet also..
But the top spring pad imo would be the part that could wear or break-apart & make noise..
The rear springs can/will eventually destroy the foam insulator. When it does, the rear springs will get noisy over bumps. This past winter destroyed mine. found the foam pieces in my driveway.
I have not looked at replacing them yet. In the old days we would just buy a piece of heater hose, split it lengthwise rap it over the top turn or two of the spring. Securing it with wire ties if it loose before installing the springs. Not sure this will work on the HHR. I don't know if there is enough room on the top coil. It might be worth a try though.
If you are asking me? No not at all, two pieces and made that way. The foam bit actually was still in good enough shape to put back in. (I call it foam, for lack of a better term.... rubberlike semi porous material is too long to say... )
EDIT: You can see very clearly in the fifth photo in this post..... https://www.chevyhhr.net/forums/show...04&postcount=7
The purple piece is the hard plastic.... that brown piece is like a rubbery/foam washer........ You can even see where the old springs were as it's a white color. Mine looked just like that.
Greybeard,
The round foam like material that goes between the spring and the bumper is what was cracked and deteriorated.It had radial cracks going from the inside to the outside. I could pull it apart by hand easily if I wanted to. It does appear to be 2 pieces, as it doesn't seem attached to anything. As bad as it looks to me , there must be metal to metal contact going on. The noise is more apparent when the body is leaning around corners.
The only OEM replacement I have found was the SS replacement at GMPD.
I could cut a replacement out of some rubber or Viton material I have at work to insulate it.The noise is driving me crazy!
Thanks for clarifying, I wasn't exactly sure what you were looking at.... As someone posted above the foam does give out. (mine hasn't yet) Metal to metal contact would mean the purple piece has bit the dust too.......
Greybeard,
Lake Runner
11-06-2012 09:15 PM
