Rotor selection
Old 02-17-2012, 08:28 AM
Give this thread a read, there's also an imbedded YouTube clip....
https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/proper-rear-drum-brake-adjustment-procedure-36754/
843de is offline
Old 02-17-2012, 08:29 AM
Hmmm, great minds thing at work again. What do you think Mike?
843de is offline
Old 02-17-2012, 08:55 AM
db/sb's Avatar
It's actually easier than that video shows. I use a set of tools that are designed for doing drum brakes. Had them for years. A doulbe ended 'star wheel' adjusting tool, brake spring pliers, brake spring removal/installation tool, etc. I'd never use 'cutting pliers'(?) to hold a cable. Also I always use brake cleaner and compressed air when I do brakes, front or rear.
db/sb is offline
Old 02-17-2012, 09:32 AM
BlackknighT's Avatar
Ditto
Mike
BlackknighT is offline
Old 02-17-2012, 03:25 PM
1970judge's Avatar
^ Thanks. I will google search the rest. I do not own a 1970 GTO, it has been my favorite car since I was around 11, the first time I saw one. Kind of made a name for myself in the community as '1970judge' so I've stuck with it.
1970judge is offline
Old 02-17-2012, 04:42 PM
  #26
I used my small vise grips and not the side cutters to hold the e brake cable but about the same to replace the shoe o my 07 , I adjust every oil change and not shaken all over !!
Oldblue is offline
Old 02-17-2012, 06:28 PM
  #27
solman98's Avatar
Originally Posted by AC66Bronco
Im willing to bet you are to soft on the brake and keep it pressed longer than needed.
get on them harder for shorter periods of time.
Ever driven in Atlanta?
Not seeing too many recommendations on rotors.....
solman98 is offline
Old 02-18-2012, 06:20 PM
  #28
1970judge's Avatar
My choices in rotors have/and will always remain the same.
1)Brembo
2) Stoptech
3) ATE
ATE being the only manufacturer of rotors for our cars (out of those three).
Old 02-18-2012, 09:53 PM
  #29
Don't forget Wilwood, they make serious rotor setups for our rides.
Kinda pricey... Dlvrnit (Kevin) has the Big Brake set-up from them on his...
sleeper is offline
Old 02-21-2012, 05:40 PM
  #30
barfan1's Avatar
Raybestos rotors are almost all sourced from China now, these US and Canada sourcing ended about three years ago. ATE is owned by Continental(Both are owned by the company I work for that nobody knows) and are OE suppliers to many manufacutrers, they make some good product, I almost bought those rotors but they were a little too expensive for my budget.
barfan1 is offline
Quick Reply: Rotor selection
