spring tech springs, good? bad? ugly?
http://cgi.ebay.com/ebaymotors/SPRIN...spagenameZWDVW
now i have heard of these springs before i just cant remeber what i heard someone remind me
Here's a quote from another thread that is HERE...post #11.
Originally Posted by cjuetten
If you are looking for a cheap, simple solusion to lowering. You could buy a pair of Spring Tech lowing spring. They lower front and rear the same amount. After you put all your gear in you would still have clearance. They're about the same price if not cheaper than other spings.
I installed Spring Techs in my HHR. I've had over 600lbs of stuff in it. It never bottomed out and road level. The spring tech will give it a slight rack, (not as bad as some of the photos posted here) basically maintains the stock rake only lower. I have over 8,000 miles on mine and I've never bottomed, rubbed or had any suspension problems.
The one thing I can't figure out is why none of the lowering springs come with specs. When I order springs for my race car I know the Spring Rate, Installed height, Installed Pressure, Harmonic Frequency all this on a $30 spring. Double the money and you get half the quality and all they can tell you how much it SHOULD lower your car.
allright good feed back, yes in MOST cases you do get what you pay for hopefully this is just a good spring at a reasonable price i mean its not like its for 75 dollars
i had spring tech springs on my grand prix gtp, and i had them on there for about 2.5-3 yrs, and never had a problem, and the car rode pretty good. i too bought them off of ebay. best spring i bought. i thought anyways.
mellojoe
01-02-2008 11:52 PM
