Still have rattle in front end
Old 01-08-2012 | 09:44 AM
SteveMaine's Avatar
Rattles
My 06 HHR has always had rattles in front and rear. But they are getting louder. I have tighten up all the bolts I could find. Dealer is no help because of coarse out of warranty. I hate to spend money to replace struts if thats not the problem. also was thinking about front struut bearing plates. Has anyone had the same problem?/ If so whats the Fix? Thanks
Old 01-08-2012 | 12:15 PM
BeanWagon's Avatar
Try looking at the sway bar bushing first. They usually are the first to go and the easiest to replace and the cheapest. I crawled underneath and lifted the sway bar with a big flat head screwdriver and it had a lot of play. I think they're $14 at the dealership.
Good luck
Old 01-14-2012 | 08:39 AM
SteveMaine's Avatar
What size sway bar bushings
I have a 06 HHr and want to replace sway bar bushing with the greaseable ones. What size should I order?? Thanks
Old 01-14-2012 | 08:44 AM
You will need 25mm
Old 01-14-2012 | 08:56 AM
X 2
Digging your new "Poindexter" avatar there Sam,
Old 01-14-2012 | 03:21 PM
SteveMaine's Avatar
Tie rod end links
I'm going to install new greseable sway bar bushings and noticed someone recommened also installing new tie rod end links. Is this the same as a tie rod end? I had never heard of them called tie rod end links. thanks for any help.
Old 01-14-2012 | 03:40 PM
What you're thinking of are called "sway bar end links", they are utterly unrelated to the tie rod ends. Give the following thread a read on the issue and the best solutions found by folks here.
https://www.chevyhhr.net/forums/show...ght=sway+links
Hope this helps, as an aside, I used the grease-able Moog parts and the "HHR clunk" has been banished from both my '06 and '07 HHR's.
Old 01-16-2012 | 03:11 PM
z06vette's Avatar
My rattle from the rear was the rear door latch assembly. Once that was replaced no more rear rattle.
Old 01-16-2012 | 05:32 PM
alexrckid's Avatar
was there any MOVEMENT(of any kind) in the rear door..?? did it ever appear to be not latching tightly..?? just wondering since i have a similar noise in that area but havent been able to detect any looseness in the way that the door is latched....thanks
Old 01-31-2012 | 04:26 PM
z06vette's Avatar
No movement. Door closed solid. But still rattled. Once I told dealer about it, they replaced latch assembly and rattle is gone.
Quick Reply: Still have rattle in front end
