Suspension Techniques Anti Sway Bar Part Numbers
Old 03-17-2009 | 10:51 PM
MWG2's Avatar
Thumbs up Suspension Techniques Anti Sway Bar Part Numbers
I have been asked about Car 11's anti sway bar, so...
Suspension Techniques Anti Sway Bar Part Numbers for HHR:
Front & Rear Kit: 52490
Front only: 50490
Rear only: 51488
web site: http://www.stracing.com/
Catalog: http://www.stracing.com/download/st_app_update.pdf
Rear Anti Sway on Car 11: (I know, it's a little out of focus)
Old 03-18-2009 | 01:50 AM
GRUMPEE's Avatar
Hmmmm interesting. I'm looking at your picture on a pda, so the picture may not be so clear. But looks to be only one attachement point (1 bolt per side) where as the TTR & Progressives use two bolts per side
Old 03-18-2009 | 02:04 AM
HipHotRod's Avatar
I see 2 D,
Just to the right of the shock mount, there's a bolt. Also at the opposite end.
Old 03-18-2009 | 02:25 AM
GRUMPEE's Avatar
Don,
I see it now, different mount position compared to the progress/TTR which uses the rearmost hole + middle hole
http://www.socalhhr.citymax.com/albu...051/983243.htm
looks like 2 welded mounting bungs as opposed to a plate with mouting holes
http://www.socalhhr.citymax.com/albu...051/983255.htm
See you in a couple weeks for the HB to DP cruise?
Daryl
whopper
Commonly Used Part Numbers
16
10-27-2024 08:45 PM
moonsign
15
04-09-2011 12:06 AM
Budro
09-22-2008 09:38 PM
Budro
07-29-2008 07:02 PM
saltyfishguy
13
05-04-2008 12:07 PM
