Sway bar
Old 05-20-2010, 04:20 PM
moonsign's Avatar
Sway bar
What is the size of the TTR rear sway bar?
I just ordered a rear sway bar from OTT [their Hardcore bar], and it's a 1.25"dia. bar. They also have a 1" dia .bar.
Just curious what size the TTR bar was. "Moon"
moonsign is offline
Old 05-20-2010, 05:09 PM
Doctuh's Avatar
The sway bar is 1.00" solid steel (25.4MM).
http://www.turbotechracing.com/produ...idproduct=5148
Doctuh is offline
Old 05-20-2010, 05:15 PM
peevlos's Avatar
Believe the TTR is 25.4mm or 1" in diameter, depends how you look at it.
peevlos is offline
Old 05-20-2010, 06:04 PM
moonsign's Avatar
Thanks for the info. Looks like the OTT bar is 1.25" and 4130. Thicker and stronger. "Moon"
moonsign is offline
Old 05-20-2010, 06:08 PM
peevlos's Avatar
I read somewhere that the OTT bar is hollow.
peevlos is offline
Old 05-21-2010, 01:11 AM
Also either version of the OTT bar does NOT tuck up 'into' the rear (angle-iron) axle like the TTR & Pro-Tech do..
FYI.
That was a turn off for me..
sleeper is offline
Old 05-21-2010, 07:07 PM
tim_tenn's Avatar
Just ask any of us with the TTR installed and you'll find out that we all love it. Excellent fit and excellent performance. Highly recommended.
tim_tenn is offline
Old 05-21-2010, 07:24 PM
Doctuh's Avatar
Highly recommended....if you can still get one!
Doctuh is offline
Old 05-21-2010, 08:06 PM
moonsign's Avatar
Did'nt want to getting into pi##ing contest with you TTR sway bar guys.
The OttPreforfance bar may not tuck up like other bars[as long as it does'nt drag the ground], but it's still a bigger bar, and stronger[4130 not mild steel-that bends]. Will give a report when I get it on. "Moon"
moonsign is offline
Old 05-21-2010, 10:55 PM
Moon- NP here, just mentioning the fit..
sleeper is offline
Quick Reply: Sway bar
