sway bar bushings
sway bar bushings
What is the moog # for the sway bar bushings.I got a #K90400 blue poly bushing for a 2007 HHR LT with a 25 MM bar, the moog are smaller bushing and there is no grease fitting on them thanks
bushings
Try www.energysuspensionparts.com greaseable 1nch 25 mm part number9.5161 order qty. 1 as they come as a pair tota $15.99 plus shipping USPS
bushings
I purchased the moog already but if there wrong i can get the ones fron energysuspensions. not planning to keep the car a real long time with susp. goodies needing replacement at 45000 miles not only sway bar items but looking at lower ball joints not a vehicle that sees rough roads at all. Kind of gun shy right now thanks
My take is that there are a few small parts that do need replacing (suspension bits,brakes), but once done with better aftermarket parts, the overall vehicle is pretty solid. Mine will be around for a long time. :)
