Sway bar bushings
Old 06-10-2014 | 01:55 PM
1970judge's Avatar
Sway bar bushings
Has anyone done them? Among other things, my two sway bar bushings are shot. Has anyone done them yet, and is this a jackstand fix or just a drive on ramp fix?
Old 06-10-2014 | 03:03 PM
Try the search. I am on my phone now and can not do it for you.
Old 06-10-2014 | 03:06 PM
1970judge's Avatar
Search returned nothing of value on the site, but a google search brought me to a thread on here, that the site search didnt find! Thanks.
A jack stand/blocks works ok - yeah a lot of people have replaced them with Progressive Poly bushings (as did I) - be aware that there are different sizes depending on the model of HHR. Use the search tool as Don suggested for info on replacing them (not that hard a job), and you will find part numbers in the part numbers posting with details on the different sizes.
Old 06-10-2014 | 03:14 PM
Not sure what you entered in our Search tool, but "replace sway bar bushings" gave me numerous helpful hits, including part numbers, instructions, tips.
Some people say the cradle has to be dropped - but that is WRONG!!!!! The hardest part was getting the polly bushing open far enough to slip over the bar. :)
Old 06-10-2014 | 03:41 PM
The search box at the top IS Google.
Old 06-10-2014 | 04:36 PM
the_shmoo's Avatar
Just R&R mine yesterday. You do need jack stands, 10mm deep socket and 15mm wrench to remove rear nut, there is a capture washer on the rear bolt to hold it in place, if you hold the washer and continue turning the bolt CC it will give you enough clearance to remove the nut (tight quarters) and 15mm socket to remove the front bolt, easier to reach from inside the fender well. Also found if you remove the top connection for the sway bar link it allows plenty of movement for the sway bar to R&R the rubber bushing.
Hope this helps. Good Luck.
Old 06-11-2014 | 03:15 PM
not a hard job at all, I used jack stands!!
kmcrae476
10
03-08-2014 07:41 PM
grugan74
37
10-12-2013 03:08 PM
OZONE
05-22-2011 09:18 PM
gordon1
17
04-25-2011 12:30 PM
